Bird.
Lorien
Nose to the Grindstone
Moderator
Hi people-
this little pocket knife is the first folding knife I made, and it was really fun to make. I still can't quite believe I made it. Looking forward to making another one soon!
Anyway, the blade is around 3.5" Cruwear at about 5/32". The pivot is 1/4" and the stop pin is 3/16", so pretty stout and maybe overkill for a knife this size. It has bronze bushings. Has a slightly chubby appleseed edge bevel, because that's what I like and I plan on making this my edc from here on out.
The handle is G10 laminated to burlap micarta, and the fasteners are titanium bicycle disk brake rotor bolts. The bolts holding the frame together are dereilleur pulley bolts.
If you want a bit of an indepth view of how it went together, mosey on over to my subforum HERE
I call it Bird because I can't stop flipping it.
Thanks for checkin it out!
PS. you may have noticed that the pocket clip seems familiar, and sort of trashy. Well, it's from your standard issue, stainless steel Olfa knife. I designed the handle to be compatible with Olfa's clips just in case there's a clip emergency, but I'll be making a titanium clip for it at some point. It'll be a little tricky but it's a neat concept that I haven't really seen done. So, I'll follow up when I get er done
Wonderful, Lorien !
Would love to know more on how you paired the lock-face.
And I love 0.25” pivots :)
Wonderful, Lorien !
sorry, what do you mean by 'paired'?
Mate / calibrate .... not sure of the right language, Lorien. When I look at a Spyderco linerlock, for instance, I can see that they hammered it a bit to fit the tang. Just technical curiosity. If you can't disclose, I understand. Thanks !
gotcha! Well, procedure-wise, I cut the lock bar slit first, then the lock bar face. One of the last steps was grinding in the lock face on the tang, and I did that bit by bit until the lock bar started to engage. Then I flipped it a few hundred times and made some more tiny adjustments. The engagement isn't full contact yet, and although the lock up is super solid, I may yet adjust the lock face of the tang slightly for full engagement. I'm thinking it'll gradually wear to that point, so as long as it's lock up pretty good I'll probably leave it be. It had some pretty serious lock stick, but after many many cycles, that went away.
