This was an eBay purchase and I knew going into it that it had a really bad and inconsistent edge from a grinding wheel. It actually turned out to be a good thing that it was so dull because it was easier to work with for my first hang. Now that I'm sharpening it I'm finding it extremely hard to file (hard steel). Stones are working very well (coarse traditional stones with oil as well as diamond stones) however it has been a very time consuming process to have gotten the bit just to this point. Because files were not working well at all, I started with the coarsest traditional stone I have to get rid of the big burrs and high spots. Next I moved to a black and then blue DMT stone and finally I've been using a Spyderco Triangle Sharpmaker, starting with their CBN reprofiling rods then moving to the standard grey and white ceramic rods.
There are a few places where the profiles meet properly --and the blade is very sharp. In those spots it is now sharp enough to shave hair from your arm. However, where both sides of the bit profiles do not meet properly (one side still has the grinding wheel profile), it is not dangerous-dull but it is not properly sharp.
Realizing that fixing the profile means removing metal, should I just use the hatchet as-is, knowing that I'll eventually get to a profile I like through repeated use and sharpening? I've not finished hanging it yet but I think even the dull spots are probably safe/sharp enough to split kindling/small wood with. My biggest concern is the uneven bit profile from grinding by the prior owner. Will it be awkward or unsafe in any way to use with a non-uniform bit profile? I don't want to ruin my first hang or loosen the head because every time I chop the head is twisting or torquing.
Leave it or keep taking metal off?
Thanks.
Thanks.
