How To Bit of a sharpening mystery
Recently, I spent some time sharpening several of my folders, using a Sharpmaker. Those were a Delica 4 PE saber grind, Native, Leatherman Crater, Ontario RAT II, Buck Vantage Select (small) and Vantage Select (large), all at combined 30° bevel. All were hair shaving sharp. I like to finish by hacking a sheet of tissue paper, and a clean cut means I’m done. All of them did so, except for the large Vantage. I worked on it some more, it shaved just as well as the others, but I still could not get it to slice tissue to save my life. Does anyone have any ideas about what’s going on here?
My guess is the apex is not a keen as you want it. Maybe some micro chips that cant be seen with the eyes. Try stroping it.
Probably a burr (wire edge), as mentioned previously. A burr will shave all day, if that's the only test. But a fine burr will quickly fold over in doing much of anything else, even cutting paper.
Using the ceramics on the Sharpmaker increases the likelihood a burr is the issue. With some ductile steels, touch has to be nearly perfect to avoid forming new burrs on ceramic hones. So I'd expect to see burrs, to a larger extent, when using the SM.
David
David
Thanks for your reply. This is the first I learned about this issue. The SM worked well with the other knives, but maybe you’re right. I have some DMT Diafold sharpeners. I’ll try them and report back.
Well, I went at my Vantage with a DMT fine sharpener, and it worked! I don’t know for sure whether it eliminated a folded wire edge/burr, but it did the trick, and pronto. Thanks all for the help.
That's exactly what I would've expected. :thumbsup:
A diamond hone cuts much more cleanly, with less effort and with less burring issues. It's what I've come to like about using them, especially as compared to ceramic hones.
David
