- Sep 25, 2019
Hey everyone,
I recently started heat-treating W2 and have had the same issue on two separate blades: a sort of ghosting on the blade that looks like small clouds. The best way I can describe it is that it looks a bit like the way a hamon looks after you've just sanded the scale and decarb off the blade. That sort of very faint cloud where the difference between the two hardnesses is.
Problem is that I'm not doing a hamon on these blades. I'm using a Paragon at 1460, and straight into Parks 50, tip first and edge down (into the oil at about a 45 degree angle). I'm doing 8.5" chef's knives, 1/8" blanks with no grinding done to them, and quenching right into the can that Parks provides.
I'm noticing the ghosting mostly around the spine and nearest to the tang, where the blade is closest to the surface of the oil when it's being quenched. Wondering if maybe some parts of that area aren't hardening fully, and that's what's causing the ghosting? I thought it might be decarb that I hadn't ground through at first but I took off quite a bit and the ghosting didn't disappear.
Additional remarks: the patterns are different on both sides, and don't seem to correspond to each other in any meaningful way.
Any insights are appreciated. If nothing else I think I'll switch to a vertical tube for quenching, and see how that works.
