- Nov 9, 2013
I have no idea if this will help anyone or if there's a better way to do this and I'm not aware of it. I wanted to strip my BK15, but not lose the company logo and model that's laser etched. So, I started reading up on these forums and elsewhere and I found a few decent ideas and suggestions, so I decided to use PCB etchant. Main reason is, its really easy to find (radio shack), not expensive and seems to do a pretty good job. I photographed the process (though its pretty easy to do) to show how it progressed. NOTE: every application of PCB was left on for 2 hrs, then rinsed off w/ water, dried w/ a towel then repeat.
Pretty sure everyone knows what the laser etched knife looks like, but here's a shot before I started
First step: simply cover the logo/model w/ PCB. I used a q-tip. I've seen others use a syringe. Its whatever you prefer.
This is what it looked like after 2 hrs. Not much difference
After 2 more hours you can start to see the etchant digging a little deeper.
rinsed and dried off again then 2 more hours passed.....now we're where I want to be.
Time to remove the black w/ some good 'ol Tuff Strip. I let this set for about 30 mins.
After stripping, I hit it with 1500 grit sandpaper then stepped to 2000 grit. Here's the final product.....
I know this post didn't reinvent the wheel for anyone, but after going through this process, I will say that I would've been better off doing a couple more applications of PCB. It did exactly what I wanted, which was engraving the logo/model into the blade so that sanding or any other modding wouldn't remove them. I simply would've liked to see it go into the steel a little more, that's all.
Next, I will blue the logo/model and then re-sand w/ 2000 grit to ensure the blue is only in the lettering and numbering. I'm sure that will make it stand out a little more.
Thanks for any recommendations and/or comments!
-Dan
-Dan
