I have my BK-7 and BK-10 right here in front of me. The BK-7 IS the "better" chopper due to its' longer blade, but it is still pretty controllable for "fine work" as you can choke-up on the blade. The blades are pretty much the same thickness, so since the BK-7 blade is 1&1/2 inches longer, it is slightly more blade-forward balanced, but not by much. It's interesting to note that the blade of the BK-10 has the exact same profile (stubby tip) as the BK-9, rather than that of the BK-7.Originally posted by spike22
How do the BK10 and BK7 compare Glockman? I have decided that I want one of the two but I'm not sure which!
I'm wondering if the BK7 is small enough to do lighter tasks like sharpening sticks, feathering sticks for firestarting, and other finer tasks that need good control.
On the other hand if I go for the BK10 control should be easier but will it have enough weight and length to do a bit of very light chopping. Where is the balancing point of the blade - is the blade or handle heavier?
I'd be interested to know your thoughts on the two knives since you have the full trio.
