- Jul 9, 1999
Formerly known as The Bush Hog.
I've been anticipating the release of this beastie since late last year and last month I finally got my hands on one.
This is a very high quality machete IMO. I got it home and went to work on the Spring saplings and brush that eternally plagues my yard near and along the fenceline. It easily took out up to 1 1/4" diameter Oak and Camphor tree saplings along with Mulberry with one swipe of it's 14" long 3/16" thick blade.
It is a full height flat ground blade of 0170 high carbon steel. The handle is the same as the other knives in the BK&T line. Fills the hand very well and does not raise any hot spots or blisters with long use. The balance point is 2 1/2" in front of the handle and the blade, while blade heavy, is not unwieldy.
The edge geometry is worth noting here as it is wonderfully done on my sample. I decided to do a little experiment and used it to prune my Azalea's into a rectangular, flat top configuration. Using horizontal swipes of the big blade, it sent that post flowering spring growth flying and I wound up with a hedge that looked like I took the gardening shears to it. Very nice flat top on the hedge.
Then I attacked the Boxwood bushes with the same results. If you are unfamiliar with Boxwood, it is a fairly dense, very woody bush you most often see pruned into balls or squares in some o the better maintained gardens here in the south. Makes a really great hedge as it is THICK.
After I finished all the whacking and chopping and such, the blade was still very sharp. It will still shave hair from my leg.
I almost forgot to mention the sheath.
It is a Cordura looking affair with a flexible plastic kind of insert. It is not custom fitted or anything but it carries the machete and is a step above the average canvas type sheaths one usually gets with a machete.
I won't give it the Cliff Stamp Torture Test treatment, so I cannot comment as to lateral stresses and breaking points and such. I'll leave that to the experts.
All I can tell you is so far I am very pleased with The Patrol Machete.
It was well worth the wait.
BTW, if you get one of these, PLEASE put a lanyard on it and use it! Tis better to be safe than sorry.
Happy Whacking!
The individualist without strategy who takes opponents lightly will inevitably become the captive of others.
Sun Tzu
[This message has been edited by misque (edited 06-03-2001).]
Happy Whacking!
Sun Tzu
