Has anyone tried to mod the BK 14/24 stock sheath to fit when this knife fitted with larger scales? Can a hair drier or other heat source soften the sheath to re-conform to larger scales similar to what Kydex can do?
OK, I decided to search the web about glass filled nylon, since that is what is used for this sheath.
Thermal physical properties for 30% filled nylon.
Heat Deflection Temperature 264 psi. 400 °F
Melting Point (Crystaline Peak) 500 °F
...another site
Heat Deflection Temp at 264 psi 482 °F
From Wikipedia:
Nylon can be used as the matrix material in composite materials, with reinforcing fibers like glass or carbon fiber; such a composite has a higher density than pure nylon. Such thermoplastic composites (25% to 30% glass fiber) are frequently used in car components next to the engine, such as intake manifolds, where the good heat resistance of such materials makes them feasible competitors to metals.
