- Jun 4, 2009
Does anyone know if the BK2 Sheath is compatible with a Blade-Tech Tek-Lock?
Can you reply with the exact model for that teklok- i have seen other pictures of products that dont' span the whole sheath and only provide two points of contact - yours clearly makes four points. I want to be sure to get the right one.The answer is.... almost. Or put another way, yes with customization. I used a teklok with my BK2 sheath, but I had to forcibly remove the nylon webbing and cut out the rivets. Then, the holes in the bracket line up perfectly with the TekLok, which enabled me to screw it directly to the attachment point of the webbing.
Here's a quick snapshot, I have it set up for sideways (scout style) carry:
And here's a top view:
I have to say I LOVE this setup.... the weight is perfectly balanced with the TekLok.... almost as if they planned it that way. Hmmmm..... ;-)
OK, so i think i answered my own question, as i don't actually own a BK-2 YET, i believe (correct me if i am wrong) that the portion that i thought was part of the tek-lok is actually the remainder of the sheath of the BK-2 after the nylon has been removed. OK thanks for taking the time!
- oXide, or JWL
OK, the pictures of yours appear to differ from the products I am seeing on amazon - http://www.amazon.com/Tek-Lok-Bladetech-Tek-Lok/dp/B005KN6DIA. Yours seem to offset and drop and fit awsome. Another forum member posted some pictures that were less then optimal - http://www.bladeforums.com/forums/showthread.php/823937-Good-pic-of-tek-lok-on-BK2-vertical-carry When i checked out the blade-tech website i could not find an exact match to your but i did see this - http://www.blade-tech.com/Drop-Offset-Attachment-w-ASR-pr-961.html. Do you have a link or something from where you purchased it? That would be great!
