wolverine_173
BANNED
- Oct 21, 2013
Is the bk24 much harder to sharpen than the bk14/11
D2 takes considerably longer, if all other variables are equal, to remove the same given amount of steel with the same tools or methods. 1095 literally has no hard carbides at all (chromium-, vanadium-, tungsten-carbides), so the hardness of the iron/carbon matrix steel is the only limitation. That's determined by the spec'd RC hardness for the blade, which usually won't account for the carbides at all, if present. D2, on the other hand, has an abundance of hard chromium carbides, which are much harder than the matrix steel (iron/carbon), and will not abrade nearly as easily...
I'd bet the 'cementite' carbides aren't quite so hard (70s RC), or their size isn't significant to be an issue anyway. Were it the case, even the 'old school' Arkansas stones may have trouble sharpening it (and that was never an issue with 1095, so far as I know). This is why I stated there won't be any carbides influencing difficulty of sharpening 1095 with today's methods/materials. Mid-70s RC is in the same hardness range as (or perhaps harder than) chromium carbides.
Crucible has listed chromium carbides at 66-68 HRC, Moly/Tungsten carbides at 72-77, and Vanadium carbides at 82-84, here: http://www.crucibleservice.com/eselector/general/generalpart1.html .
Here's a link to another page, with Knoop hardness values for many materials, including Cementite (iron carbide) at 1025 Knoop and chromium carbide at 1735 (70% harder than Cementite, by this measure). See the 'Hardness of Materials' chart lower down on this page:
http://www.tedpella.com/Material-Sciences_html/Abrasive_Grit_Grading_Systems.htm
David
