No problemEdd-UK said:thanks thats all i need to know. just got a sharpmaker 2 day.
very pleased with it. but i think i will go for the standard 40 as recemended.
thanks again.
Edd
:nod: ... I don't have a steel or even know how to use one, but I agree with what you've saidanomad said:As I understand it, the reasoning behind using a 40 degree setting primarily and only using a 30 degree angle is to reduce the amount of steel you remove from the knife each time you touch it up on the rods. At 30 degrees you are removing more metal than 40 degrees, so if you are sharpening the knife a lot (like a butcher or something) the knife will wear out faster.
Also, the two bevel edge with a primary and secondary bevel, according to some, give a better cutting edge because it creates an almost convex shape.
Something I have found very effective with beckers is a good steel. After some light work with any of my beckers a few passes on the steel has them right back in shape! Eventually they will need a trip down the ceramic stones, but steeling really prolongs edge life.
