The feral pigs sometimes show up in late February. I have neighbours with an orchard, and in past years the hogs turned up when the fruit started to drop. Naturally it is best to have my traps set before they arrive.
My preferred traps are spring-up leg snares based on an ancient design. I've made them using metal components for the trigger mechanism, but this year I intend starting off with using a trigger made from wood. So today I went and cut some sticks to make part of the mechanism. The trees I cut branches from were barberry. This is an introduced plant (danged if I know why somebody thought they should plant it here). It grows some nasty spikes in sets of three, and I guess I've been stabbed by these dozens of times. Under the bark, the freshly-cut wood is bright yellow.
If you are curious as to how the trap mechanism works, below is a link to a video of a Malaysian (Indonesian) trapper setting something similar. These traps are very effective. I've caught heaps of pigs in them, along with a few other species. If you set the spring device (I often use rubber shock cord) to lift the noose only just high enough to tighten it around the animal's ankle, it is a fairly humane thing as far as traps go. Non-target species can be released, although care is required.
Click on the link to see the video: Making a spring up leg snare
The BK9 really shines doing this type of work. I prefer it to a hatchet or a machete. I haven't had to sharpen it for ages.
