Blackout clip!
Do they make a aftermarket clip for the kershaw black out or one that will just happen to fit it and be alot tighter than the factory clip mine simply falls out of my pocket if i lean back to far iv tried bending it cant get it
Yeah not the strongest clip. I compared my Spydies, BMs and Cold Steel but nothing matches. Too wide.
Good knife though, I've had mine for quite awhile.
Good knife though, had mine for quite awhile.
Dang. Yea good knife i like it and want to carry it more just afraid to cuz it slips ofd my pocket so easy
You're probably bending the clip in the wrong spot. Try holding the top of the clip where the screws are with channel locks and bending the clip in. It will take a bit of force, you can't just bend the clip in the middle. A buddy of mine had one of these for years and he never had a issue with the clip.
Jay, where are you bending the clip??
Like Tyler above says, unless you bend it right past the mounting screws, the clip won't have any strength.
Joe
I've bent a lot of clips (probably at least half I own) and the advice above is solid.
