Retails for $249.00.. Your Choice $119.00 Shipped anywhere CONUS
Available in Black, or Coyote Tan
Drop Point Combat Fixed Blade Knife or Tanto Point available.
Tanto Blade offers excellent piercing strength in blade tip. Perfect stopper for doorjambs
Drop Point Blade is a solid utility knife that works in most applications.
Sawtooth serration on blade spine offers a secondary cutting surface that is effective on rope, webbing or can saw through wood. Deep, flat bevel grind gives a razor thin edge.
Blade material: 154CM stainless steel hardened to 58-60HRC.
BT2® Black Blade absorbs light, allowing easy concealment and impeding blade corrosion. Tang:
Solid, full-tang foundation.
Protruding tang with lanyard hole provides a window-breaking edgesturdy enough to pound a nail.
G10 scales machined on wrap handle provide a firm grip. Sheath:
Strong and durableConstructed from molded Kydex®/Thermoplastic.
Keeps knife and user safePrimarily designed for inverted carrying so knife wont fall out.
LockableTwo detents keep knife secure.
Easy carryCan be mounted for high or low carry. Holes allow for lashing to leg or arm for customized carry.
Fits up to 2" belt. Dimensions: Blade Length: 4.5" (11.43cm) Thickness: .115" (2.92mm) Overall: 9.45" (24.00cm) Weight: 6.20 oz. (175g) Handle Thickness: 0.5" (1.48cm) Sheath Weight: 3.44 oz. (97g)
E-mail Cntrsnipr@aol.com
