- Jul 14, 2011
Just wondering if a knife blade could possible break a window. Also, would substituting blade steel for a carbide tip in a window breaker work? Such as the umnumzaan's window breaker.
a folder? not likely. some up-coming spydeys will have carbide glass breakers incorporated, i think. the rescue will have a glass breaker that emerges only when the knife is gripped in the closed position.
The harder the material hitting the window the easier it is...thats why carbides are used...
I wouldn't hesitate to use my ZT0300 or CS spartan.
I`d use the blade of my CQC-7. The tanto tip should go through a window without any problems. I want to try it out tho.
Again, it's not so much about the HRC, it's about the distribution of energy on impact, i.e. how much pressure (force/area) are you exerting on the glass and how much of the energy is the glass able to deflect/disperse rather than absorb. A slow-moving large object of high HRC (e.g. brick) impacting the window with a flat surface thereby distributing its kinetic energy over a wider area may have less chance of breaking the glass than an aluminum can of relatively low HRC with the same kinetic energy impacting the glass at a tiny point.So the blade won't be able to break the glass? How much HRC would you need to break it easily though?
In practice this means that the glass breaker need only be hard enough to not have all of it's energy dispersed through material deformation on impact.
If we are comparing ONLY hardness of objects, i.e. controlling for shape as well as mass and speed (kinetic energy) etc., then harder objects will deform less upon impact and so require less impact energy to break the pane of glass... but how much less energy? Steel at air-temperature is relatively hard even at only 30 HRC (well below ceramic levels). Putting an equal amount of energy into a steel vs. ceramic glass-breaker identically shaped like an arrow field-point (standard glass-breaker shape), I doubt you'd be able to detect by hand a difference in the amount of energy required to break a pane of glass. If one was hardwood or hard-rubber instead, THEN the difference would be detectable - the softer material would require more energy to induce the crack. I don't have any numbers though.
