- Feb 23, 2009
STR-
You've mentioned in several threads knives coming in for work that needed blade centering.
I have a Benchmade mini-Ritter/Wilkins grip that is off a bit, functional, not touching liners, but off enough to bother me.
Question is, what could I do to move that blade position closer to center? Before you ask, with the pivot screw unscrewed versus clamped down yields virtually the same blade position. Also, I've swapped bushing washers from one side to the other (same diameter) with no difference.
What else could I try? It's not worth sending back in to BM.
Thanks!
Thanks!
