I'm assuming that you are talking about blade centering when the knife is closed.
I had a similar problem with one of my blurs. The blade leaned to one side, which actually made it a little tougher to open and it would scuff against the liner as it closed. After taking it apart and back together nearly a dozen times; trying out the paper trick and anything else I could think of, I finally realized what the problem was. The liner-lock bar was simply going too far inward, actually pushing the blade into the other direction. This is what made opening the blade tougher, since the little bump that helps rotate the blade and also lock it in place was being pushed deep into the indent.
So what I did is I opened it up one last time, bent the lock bar ever so slightly in the other direction until it kept a few millimeters that way. Now the Blur opens up fast and closes clean, and sits in the very center of the handle when closed! Problem solved! The only catch is that after taking apart the knife and putting it back together so many times, all the loc-tite seems to go away so I ordered some more to keep the pivot screw from loosening itself. Hope this helps somebody else!
