only problem is, i will likely never have 10 blades ready at the same time for most of my year, so if you don't mind me asking, how pricey once you factor in everything? lets say you were gonna mix up enough for 5 blades?
Cerakote is $45 for 4 oz while KG Gunkote is $10 for 4 oz.
Four oz is more than enough to do a shotgun including all the small parts so you can do quite a few knives with that much.
I assume you already have an air compressor since you have a blasting cabinet. You will also need:
-An airbrush, a cheap one is ok $10
-Canned air or a moisture trap and thread adapter for your compressor to power the air brush $8
-100 to 120 grit AO $30
-KG K-Phos surface treatment (not absolutely required but it does help) $12
-Wire to hang your knives
-MEK to clean the steel before applying the finish $6
-An oven thermometer because most ovens aren't correct $4
I don't have any experience with Cerakote but from all accounts from experienced people it's at the very least as good as Gun-kote. Many say it's better. Chris Reeve uses Gun-Kote if that means anything to you.
I have used Gun-Kote and will probably continue to use it. It is durable, it looks good, and it's easy to apply. I don't like the look of powder coating or Duracoat (which is an epoxy finish) because they're thicker finishes. If you're trying to hide heavy grind lines then those are options. When you compare wear resistance you have to consider coating thickness. Powder coating and Duracoat can offer long finish life because the coatings are so thick. I've seen guns with Duracoat that looks like it's probably 0.015" thick. Gun-Kote could be 10 times more wear resistant but at 0.001" thick it's going to wear out faster.
