- Nov 28, 1999
I have etched a few damascus blades before, as well as a few differentially hardened carbon steel blades, to bring out the temper line. I thought I had the process down fairly well.
Last night, I was etching 2 blades. One was damascus and the other was a clay hardened W2 blade that Nick Wheeler heat treated for me. The damascus blade was handrubbed to 600, but the W2 blade was only about 220 and still had some coarser scratches visible from the grinder(yeah, I know, I just wanted to see that line).
Instead of simply using hot water from the tap, I used filtered water and put it in the microwave for a few minutes until it was good and hot. Maybe too hot. After cleaning the blades in a warm solution of TSP and water, I dried them and put them into the solution of hot filtered water and Archer's etchant. Probably a little under 50% solution. When I say maybe the water was too hot, I mean the solution was actually bubbling when the blades went in. I didnt think the water was that hot, but the plastic cup I used was too hot to hold onto for more than a second or two needed to take it from the microwave to the table. The blades were allowed to stay in the solution for a few minutes, and then I took them out and wiped them down with clean paper towels and lightly wiped them down with 600 grit paper. This was done about 3 times.
The damascus blade, after sanding with 600 grit paper, seems ok. The W2 blade, however, is really rough looking and is very hard to sand on. I mean, I took a piece of 120 grit ceramic belt, and it barely takes any color off. It does nothing to the rough etched finish, not to mention the leftover coarse scratches from the initial grinding. I even took a piece of a new 80 grit Regaloy belt, and rubbed on it. That rough finish is still there! What did I do to this blade? Did my using boiling or near to boiling etching solution do this? The damascus blade took a good bit of cleaning up too, and seemed harder to finish.
