- Jul 11, 2018
So up til now, I haven’t really shot for a mirror finish On my knives, and anything about “that” or anything relating, I’ve always relied on info from YouTube for so I figured I’d ask the experts;
hiw do you guys finish you blades? What steps and tools do you use to achieve these nice matte/mirror finishes? Do you do it all hand sanding? Before or after heat treat or both?
I’m always curious about easier ways to go about making my knives look nicer. I’ve read about cork belts and scotch bright belts and gator belts.. and all that sound rather expensive maybe minus the cork belt route.
if I’m not going for a rough Aesthetic
I typically just grind my blades out with 36-40 grit (maybe 80 if I’m out of blaze belts) then clean things up with 220, bring it closer to final shape and usually hand sand from there and usually end with a red scotch bright finish. I’m really Leary about taking a knife back to the belt grinder to clean it up after heat treat save for the grind lines; worried I’ll ruin the geometry
is there a better alternative to a couple hours of hard hand sanding work?
(I wanna start messing with ferric and media tumbling but that’s another topic I suppose)
