- May 25, 2015
I've got some steel on order and among others I picked up a bar of CMP-M4 1/8x36"x2". I intend to use it to make a couple of chef knives, but having never used the steel, and there being very little information about its use in knife making, I figured that this would be the place to ask a few questions about it. Now ordinarily when I make chef's knife out of W2, I profile, rough grind to .030"-.040" at the edge, I heat treat, straighten, and finish the grinding, and convex the blade so that the edge is <.003" and the spine tapers from full thickness at the tang to .050"-.060", 3" down the blade (on a knife with an 8" blade) and to about .020" a half inch before the tip. I opt for plunge-less grinds on chef knives.
I think I already know the answer, but can I go that thin with M4 and expect the blade to hold up, or will it just chip? I temper my W2 knives to around 63 hrc (according to the HT data sheet), I'd like to leave the M4 at least that hard. Can you recommend a more suitable geometry for this steel on an 8" chef knife? Will I be able to do any grinding pre HT on this steel, or should I just suffer through doing all the grinding after its hardened? Can this steel be drawn back the way more conventional ones are?
