Nice knife, RCR.
As a 1084 guesser myself, here are my 2¢:
.020" behind the edge will cut well, and most people will find it sharp, and it will hold up to hard use. This is about the geometry you'll find on Spyderco value line like the Tenacious and Resilience. I feel these steel are similar in performance to 1084, being low wear resistance, but high toughness.
.015" behind the edge, and most people will find there is "something special" about how it cuts,
intelligent hard use.
.010" behind the edge and it will
amaze most people with how it cuts, but you'll want to avoid twisting or prying cuts in hard wood, or for skinning, hard strikes against bone;
My guess is that with the heat treat you mentioned, then this geometry, with a 15° per side primary edge and a 20° per side toothy microbevel will be strong enough to handle intelligent hard use, and will be stable enough to cut well for extended periods of time between sharpenings, especially if its microbevel is honed routinely and kept toothy. Try it and see?
You have a pretty tall blade and you could take the grind up higher ...I’m thinking .035 might be a better number for you to try to reach at 7 mm from edge
This is about the geometry on my own EDC in 1084, and .012" behind the edge; I tempered it twice at 400°, and used the sharpening protocol I mentioned above. It handles all EDC (paracord, cardboard, packages, plastic), and wood carving just fine, and prying cuts in dry twigs and branches causes some microscopic deformation I just can feel with my fingernail, but not see by my naked eye. The edge does pass the brass rod test quite handily. I'm tempted to bring this one down thinner, and would if the knife didn't have a pointy wharncliffe tip that's already as fine as I want to go. Speaking of which, thanks for the thread, as it reminded me to hone this baby.
I have no idea how thin your steel and heat treat will support. Without controlled heat treat, we are guessing.
1084 is a good steel for guessers. Guess, then grind, then gain good ground on genius.
