- May 23, 2022
So I was reading this amazing article here about blade geometry impact on edge retention. My mind was blown!
Given these results:
How would a high edge retention steel at a higher edge angle compare to a high toughness steel at a smaller angle in relation to edge retention?
So for example wouldn't a lower edge angle (for example 20 degrees) on a high toughness 3V steel OUTPERFORM a high edge retention steel like S90V at a common 37 degrees edge angle as far as edge retention is concerned? And then at the same time wouldn't the 3V also be vastly superior in regards to toughness compared to S90V as well. Even though the lower edge angle decreases toughness, 3V with 33lb/ft is probably 6x tougher than S90V - which I believe is at 5lb/ft for toughness... so 6x the toughness should provide an overall tougher blade than S90V with the bigger angle? 6x the toughness should make up for half the material missing..
So could high toughness blade at lower angle be the holy grail for high edge retention AND high toughness?
I am sure many smart minds have thought of that, so I would be curious what the issue is with such an approach?
