I've read books and web site tutorials about forming the fnife blade and I'm sort of confused. They say to start off with say a 60 grit to move metal., The next smaller grit is used at a 90° angle to the first to remove the gashes left by the first grid. The next smaller grit is done at the first angle which is 90° from the second grinding...and so on and so on until you are finished. Is this right or not?
Second question is how do you grind at a 90° angle from the first (which would be down the length of the blade) and not mess up the pummel? Or can you not do this if you have a defined edge at the pummel? Does this procedure depend on the shape of the blade?
Please set me straight.
Reid Allen
Reid Allen
