Blade HQ Recon 1 exclusive Coating?
Hi
I believe old CS Recon 1 (with AUS8A steel) was cheaply black painted and yes - the paint would go off if you just stared at the blade long enough. I heard the new Recon 1 with CTS XHP or S35N is DLC, which should be much much more resistant to scratches.
Hi, would you know what coating is used for the copper colored versions on the Blade HQ Recon 1 exclusive?
Mmmmhhhhhh.... Maybe the exclusive deal with Blades Canada is in the way? I just want a satin, spear point Recon 1. Ideally with OD handles.
I could buy the Blade HQ copper color exclusive and have the PVD removed, revealing a satin finish (maybe?)
I also would like a spear/drop point satin Recon 1 (4"). Green handle is probably a little more interesting to me than black. Must be a lot of us out there. Come on Cold Steel, the Recon 1 is a great knife so give use some more variations to choose from!
The out of stock blades Canada recon 1 in satin drop point and FG and lower lockback pressure (required) would be great but even better with some handle color options.
