Blade Life
I have a Benchmade Osbourne Axis with 154cm steel blade and I was curious how many sharpenings this blade would take before I would need to replace it. I tried to sharpen it for the first time, which did not go as I expected, and I took about 1/2 a mm off of it. If I have to do this 3-4 times a year (which would be alot, since it stays sharp a long time even with frequent use) then would the blade last only 5 years or so?? Thanks for any advise.
Randy Elassal:confused: :confused: :confused: :) :barf:
It sounds like an excessive amount of steel to remove for one sharpening. Were there deep nicks or chips on the edge? If you need instruction, I would suggest you search sharpening threads on BF (there are several in the last few months). You should be able to sharpen a blade several times before you remove that much steel from the edge.
If you keep a consistant angle, try about 20° per side, a diamond hone will sharpen anything.
You sharpened away 1/2mm of blade steel????
Either you used a power grinder, which is the wrong thing to do, or you've got very strong arms.
Sharpening normally removes well under 1/1000th of an inch, maybe about 5-10um.
BTW, welcome to Bladeforums, Mr. Randaximus. So, according to your profile, you are a project manager in Iraq. That must be very interesting work right now. I'm glad to see that you've got internet access. We'll look forward to your posts here.
I agree, please let us know about the day to day there. Oh yea! WELCOME! Paul
