Recommendation? Blade over etched?
So last night I was working on a couple blades that I would like to stone wash. I have limited experience stonewashing blades and have only done a couple so far. So one of the first blades that I was doing I think was over etched? I say this because I ended up with a dark spot in the middle of the blade right at the bevel line on BOTH sides in the same spot.
My procedure for this blade was 36-80-120 grit ceramic belts followed by a A100 then A45 trizact belt, I do have a cork belt but I didn't do that step. My acid etching solution consists of a 50/50 ratio of Ferric Chloride and distilled water where I etched for 9 minutes total in 3 minute intervals. On the first two intervals it was going great, then on the last interval when I pulled it out of the acid that's when I got the dark spots.
My question is what happened here? I have done this a couple times with the same procedure before. Also, do I need to be hand sanding for an acid etch or is belt finishing a good enough prep surface? If it is "over etched" can I fix it by taking it back to say the 120 Ceramic and sand it off? Or is it screwed up for good?
You didn't say what kind of steel, but maybe there's a slight "Hamon" ,or differential heat treatment going on there. Nice looking blade!
An etch is only surface deep. Sand it down and try again. 50/50 mix is pretty strong. Try 3:1 up to 5:1 ( water to FC).
A dark area is sort of normal. I usually rub the blade down with oil and a very fine abrasive sheet (3M pink or white cloth) or 0000 steel wool after etching to remove excess oxides and even out the etch.
Oops, it’s 1084 from NJSB.
I have a 3:1 ratio already mixed so I’ll give that a go today.
