i have a kershaw blur and a couple other knives that have developed some blade play (side to side if you're looking at the knife from the top). should i just remove the pivot and put some blue threadlocker in there?
First simply tighten it without taking apart it may be that simple. Once you know it can be fixed with adjustments and blade still deploys to your desired speed then you can leave it like that. or if the screw does looosen again then take apart and do again with threadlocker this time. I simetimes put threadlocker only on the pivot screw depending in the knife.
