- Jun 6, 2013
I have a recon 1 and it now has up and down blade play not a lot but some. Does anyone know how to fix that? It still has no side to side play tho, after tightening the pivot. Thanks for any advice.
I do not think you can fix it other than sending it in but i dont know for sure. Does it just wiggle or is there considerable movement?
The machining may need to be smoothed out a touch in the tang, and the lock back. If the lock back is not fully plunging in, you will get a touch of up and down play.
Yah, the only way that it should have play is if the lock bar is not engaging. I watched a guy completely strip down an AK furniture and all then put on new furniture with nothing but his Recon 1. Seriously torquing the crap out of the knife and still, zero play.... But if you look at models were people have used and abused them for a while the lock bar is seated further down than it would be on a new one. The lock has just adjusted its self.
so once again, if its got play the lock bar is not seating correctly.
It's VERY unusual to see any play in a Recon I. I would suggest sending it in to us (with a covering note explaining the situation) at the following address:
COLD STEEL, INC.
6060 NICOLLE STREET
VENTURA, CA 93003
UNITED STATES
Thanks
