The trailing point blades point is higher than the spine. This is typically engineered with an extended belly for slicing, with the point up and out of the way.
The point/tip is higher then the spine which is horizontal for a greater part of its length. The belly is the objective of this format, and it's used for tasks where slicing is the most important function. NB Where the spine rises higher than where it meets the handle a horizontal line should be taken from that point (ie the handle). Example = Bark River "Custom Trailing Point"
The point/tip is equal to or higher then the spine and the spine is concave. Like the Trailing Point the belly is the objective of this format, and it's used for tasks where slicing is the most important function. Where the point is higher then the spine this shape may be referred to as a Curved Trailing Point or Upswept Trailing Point. NB Where the spine rises higher than where it meets the handle a horizontal line should be taken from that point (ie the handle). Where the point/tip is lower then the horizontal spine, or line, this is often referred to as a Concave Clip Point. Examples = Case CA384 "Hunter"; Schrade "Sharpfinger"; & Bark River "Upland Special".
