Hello Everyone,
Since I'm new to this game, I hope you don't mind if I ask some elementary questions.
I was wondering about blade shapes. Are there industry standard shapes?
Is there anything along the lines of usable patterns or templates to outline a knife shape, and perhaps giving the suggested stock size of material to start out with in order to acheive that particular shape?
I guess if I knew what the end shape was to be before I started, I'd be able to better determine the stock size of material I'd have to start out with.
I know that sheet metal workers have a blue ink that they paint onto the metal. From there they can scribe centerlines,etc. for use in bending, drilling holes etc. Would this work the same with doing a knife? You hammer out your blank, you use the blue ink (forgot the official name of the stuff) on it, and by overlaying your template or pattern, you can scribe an outline of the shape to be used in grinding the finished blade shape. If I'm heading in the right direction with my questions, then my final question is going to be what are these patterns or templates really called, where do you get them, etc.
Then again it may be as simple as beating a piece of steel until it looks wide and thin enough for a knife, and you take a pencil and just conjure up some freehand outline that resembles a blade shape!
Once the blade shape has been determined, is there some kind of magic proportional formula one uses to determine the proper size and length handle based on the blade size and shape?
Thank you for your time and consideration to my questions.
