Originally posted by James Williams
Nagassa and tsuka length is very personal. It has to do with the style as well as the individual. My normal tuska is 14", most of my swords have 30" nagassa. I am 6'2" and can handle a longer blade however after many years of training my tsuka length is pretty fixed. The Japanese, even though their average height was about 5'2" used some pretty substantial blades when they were fighting.
<snip>
By the way is there a possibility that I could get some high res copies of the pcitures that you took? If it is possible I would appreciate it.
James,
Thanks again for taking the time to answer.
Understanding as one trains the fit of the sword becomes more apparent with the gain of experience - but....
there's always a but
If a novice wanted to be fitted - what would be generally considered a good starting point?
For example I have heard/read that holding the sword in a relaxed manner at one's side the blade tip should not touch the ground -
is this actually myth - or does it make some practical sense?
In terms of the tsuka/handle length - I have again heard/read that it should be about 3 fists width apart - which seems to fall conveniently into the 11" tsuka camp...
although doesn't the balance of the sword come into this -
a heavier blade may favor a longer tsuka, and a lighter blade a shorter tsuka?
I don't have much experience in this but handling different sized bokkens I often find myself with a longer than normal grip on heavier ones and even on the more standard bokkens my natural hold seems like a 12" tsuka.
Using this limited experience and logic -
perhaps some of the shorter 11" tsukas are due to iaido -
where the sword blades are alumium/zinc alloys that may be lighter than steel?
Thanks.
PS - I'll send you e-mail about the higher res photos.
