I recently got to work with a variety of folders in different blade steels to compare their abilities. Here are my initial impressions. I'm still sorting out some of the findings and re-testing others for the nth time, but all will eventually be posted. The knives were all reprofiled and then resharpened several times. Most had edges in the ballpark of 10 degrees per side. The angle measurements are estimates based on freehand sharpening angles (If you know of an easy way to measure them let me know). The sharpening process consisted of establishing a bevel with low grit sandpaper, then refining it with a fine DMT diamond stone, followed by a loaded leather strop. Microbevels and resharpenings were preformed using a fine ceramic rod followed by a strop.
If you know the RC levels for the steels listed could you let me know so I can edit the information into this post?
To view the composition of the steels please refer to the following pages:
http://spyderco.com/edge-u-cation/steelchart.html
http://www.crucibleservice.com/datasheets/index.cfm
CPMD2 - Spyderco Military - 20º inclusive with 30º microbevel
With this knife I was able to acheive the sharpest edge I've ever produced. CPMD2 showed an excellent capacity to keep extreme levels of sharpness. With other steels they would lose their hair popping edge rapidly then hold on to hair scraping sharpness for some time. Excellent edge holding ability in general. Showed a slightly increased tendancy to burr when sharpening compared to 440V and S30V. Much easier to sharpen than either of those two steels however. I'm curious as to whether the steel can be hardened to a higher RC level and if so how much it would increase edge holding and the ability to resist burring while sharpening.
D2 - Queen stockman - 14º inclusive no microbevel
Preformed similar to the CPMD2 knife except for a slightly increased tendancy to burr as well as losing its edge a bit quicker.
S30V - Spyderco UKPK, Manix, Native
The steel can be difficult to sharpen. It takes more strokes than the 440A or AUS8 knives to create a good edge. The resulting edge has a fine, consistent feel to it. Quick to lose the uppermost levels of sharpness but retains a working edge for considerable time. Very little burring when sharpening.
440V - Spyderco Military - 16º inclusive with 30º microbevel
The most difficult steel to sharpen out of the knives tested. Extremely little burring while sharpening and as expected excellent edge holding.
13C27 - Kershaw EnerG, JYD2, Storm and Speed Bump -
Sharpens very quickly. Shows a greater tendancy to burr than the other steels tested except for the 440A. Takes an extremely sharp edge but loses it much quicker than S30V or the D2 variants did. I think the steel would preform better at a slightly higher RC. I would love to get my hands on one of the 64RC knives in this steel.
440a - Kershaw Leek - 16º inclusive with 30º microbevel
Sharpens very quickly. Shows a greater tendancy to burr than the other steels tested. Takes a fine edge but dulls considerably faster than S30V, 440V and the two D2 steels. Edge holding was slightly lower than AUS8 and 13C27. In the future I'd like to compare this to a Buck knife in the same steel.
AUS8 - Spyderco Salsa, Boker Trance, Wharcom
This steel showed a high tendancy to burr on all three knives, somewhere in between 440A and 13C27 I'd say. Quick and easy to sharpen outside of the burr formation. Edge holding was good, but unremarkable compared to S30V etc.
8Cr13MoV - Byrd Cara Cara - 10º inclusive with 20º microbevel
The steel displayed minimal burring when sharpening, which can most likely be attributed to its high RC level (61rc I believe). The steel takes a very fine edge. Edge holding was closer to S30V and the D2 steels than 440A and AUS8.
Corrosion - The 8Cr13MoV developed some surface rust when exposed to sweat. The AUS8 Wharcom, 440A Leek and 13C27 Kershaws showed a much greater tendancy to rust than any of the other steels, though this is more due to the bead blast finish than steel composition. Once polished the steels showed no significant tendancy to corrode. No other corrosion was noted in the test knives.
The knives were EDC'd and used for general cutting tasks, going through several sharpenings, and used in a more controlled cardboard cutting comparison. The data from the work will be posted in the future.
If you have any specific questions about the steels or the knives tested fire away.
