Use steels in the .60-.80 % carbon range for best results with low end HT gear. I recommend 8670 from
@Alpha Knife Supply
Needs less processing to hit peaks and isn't as sensitive to putting too much carbon in solution due to lack of temp control but nothing beats having proper temp control in the end.
If your using Peter HT you should upgrade to ZAPP Z-Wear
@Alpha Knife Supply. Pay for the cryo and ask for 62-63rc. They do an job on that steel.
Some of the stainless Steels could benifit from a faster quench rate than a vacuum gas quench used at Peter's. Also low alloy carbon steels won't get the TLC needed to really shine from Peter's either. So Z-Wear.
