- Jul 23, 2015
How often do you grind blades to a zero edge? With what kind of stock thickness, blade profile, blade width, intended usage? Which steel do you use for it, and how hard do you want your blade to be to support such an edge?
The reason I ask is because I recently ordered some 1/8" thick AEB-L from Rob in Alberta, made a chef's knife for a co-worker, then had Rob heat treat it to RC 61-62. The ground the blade to a zero edge, and it behaved as a laser in the kitchen!
Also, as I was grinding, post heat treat, I clumsily dinged the heel of the blade into the aluminum wheel of my 2 x 42, while running a 1 x 42 belt. The result was a roll, not a chip, at RC 62, which was able to be mostly removed by the scotchbrite belt. This proved to me how tough AEB-L is, even at thin geometries and fairly high hardness. Quite exciting! But I would love to know what other stainless steels, especially more wear resistant ones, people have had zero grind success with, as well as the questions in the first paragraph. Thanks so much!
Thanks!
P.S. I used the search function before posting, and came up empty.
Thanks!
