- Aug 13, 2022
Just got all of my15 blades of diff shapes back from the heat treater ..all went well with the exception if 1 blade has a small warp (to be honest I expected much more) my question is this fixable?
The warp is behind the plunge line not affecting the blade (the part I want heat-treated) I was thinking I could keep the blade wet Rag etc. then block up the tip of the blade and the butt end Warp facing up. And heat a small band or area behind the plunge line (middle of the warp) with my torch and bring it back to straight with a c -clamp and my straight edge.
Do you think this might work or do You's fellas throw them away at this point????
Thanks Jerry
Thanks Jerry
