Blade Tech Knives
I got a Blade Tech Mouse-lite recently for less than $15 from Spydieguys, little brother of the Ganyana. Really a pretty nice small lockback. The blade is less than 2", about 1/8" thick, with very solid lockup and a nice grind, almost full flat grind. Blade is AUS8, and on this series, the scales are FRN, molded from what were probably some G10 scales, feels pretty much like G10. Ambidextrous tip up pocket clip. Thumbhole is nice and large in proportion to the blade, works as well as any Spyderhole. This may be a bit of a special run, with spydieguys.com etched into the reverse side of the blade.
Some minor issues. the pocketclip is a bit tight. And while the tang of the blade is nice and highly polished :thumbup:, for some reason the corner that keeps the blade closed against the lockbar is a pretty abrupt angle, and repeated opening/closing makes for a higher probability of galling on the lockbar, resulting in rough, gritty feeling operation. This could probably be remedied by simply radiusing that corner of the tang just a little, so that the tang doesn't grind into the lockbar at such an acute and minute point.
All in all, I like this knife quite a bit. Ergonomics agree with me quite well, quality construction throughout, and the AUS8 sharpens easily. I'd buy another.
You did a little better on this one vs. the Puma. I looked it up at knifecenter and they are selling for $25.95.
