Took delivery of s30v, g10 blade-tech mouse 2 and pro hunter yesterday. After a quick check, I found the pro hunter impressive, rugged and larger than expected and the mouse 2 fabulous and an edc add on (who can decide what NOT to carry?). If you like the Spyderco hole, you gotta love the v-hole; same function, slightly different (and more effective) shape. Also found a recurring disappointment: lackluster closings. Recurring generally, not blade-tech specific. The mouse 2 closing is a marginal ok; the pro hunter needs serious help: ya gotta take it all the way home. It doesnt go anywhere without help. Whatever: these models fall just short of superb because ya gotta pay so much attention to making sure the blade gets to and is secure in the handle. Brings up the following issue: is there a standard adjustment I can attempt to tighten up closings. Also, am I expecting too much when I look for robust, crisp closings in all folders, not just costly customs? I expected the pro hunters double nested liners to give it a closing performance advantage over the mouse 2s solid spacer across the spine of the handle. Thats not what happened. Maybe I missed something in the literature/specs, like CAUTION: when closing these models, extra attention required to ensure blade gets to and is securely seated in handle. When I upgrade my forum membership, think Ill build my handle around Closer or The Closer or Lackluster Closer or In Search of the Robust, Crisp Closer. So, should I go after the onliner who sold me the knives or just go direct to blade-tech. The answer probably has to be blade-tech, but when the performance gap is so obvious, you ought to be able to go back to the onliner, at the onliner's expense. If you have a reference or url to help me learn more about what contributes to strong closers, please pass it along and thank you, in advance.
