Blade-Tech Sheath for the Talon
Shortly after recieving my new Talon, I left it in the truck to show a friend after work. The sheath has since lost its grip on the knife. Now it will just fall out. Is there anything that can be done to correct this?
My Talon was a little loose too so I put in an extra chicago screw at the top of the sheath and this seems to have fixed the problem.
Ron,
Bremerton, Washington
Wow.
I better not leave my sheath in the car. I've also heard of people using blow driers to slightly remold the sheath. Maybe a heat gun might beable to fix it better, but maybe not.
I got it fixed now. The local hardware store carries the same aluminium binder post used to mount the Tek-Lok to the sheath. I drilled a hole and installed it at the top on the edge side. On the back I installed a flat fauset washer and screw, again like the one used to install the Tek-Lok. How I can adjust the friction required to remove the knife.
