- Nov 25, 2005
Does anyone know how thick the blade is on the Marble's Trailmaker?
Mine is 5.45mm at the spine. Or .215", take your pick.
But the sheath talk about limp, floppy leather. If it didn't have a plastic liner it would be dangerous.
Your's has a plastic liner?!! AACCKK!!! Mine didn't come with that, oh well...
Mine was made with about 8-9oz. leather though, so it is reasonably stiff and well made.
ENJOY!!
I've been seriously considering getting one of the newer models. My understanding is the newer ones are made with 0170-06 steel. Good stuff!
Do the edges of a convex blade also have a shinier "bevel" on the edge where it is sharpened?
Some convex blades have one smooth bevel which runs from the spine to the edge, no real distinct edge bevel. Some clearly have the edge with an individual bevel which is much steeper than the rest of the grind.
-Cliff
The edge bevel looks like a normal edge bevel, a sharper V shape.
ENJOY!!
Cliff Stamp said:Put the edge of a ruler on the bevel and see if the bevel dips under the straight edge. As soon as you attempt to sharpen them you will realize if it is significantly convex because if it is then a benchstone will only hit part of the bevel on each pass.
The newer models come with the thinner sheaths and kydex liners to keep the blade aligned and not cut through them. Adequate, but the older, thicker sheaths were far superior. One change on the new ones I very much like is that the handles are larger and longer--feels much more secure in a swing. My hand barely fits on the old models.
0170-6 steel is used on a lot of the Marble's line now, but not the Trailmakers. They are still 5160, and that is a better choice for a big blade anyway. Of course, since Camillus was really the only available source of 0170-6 (and has been providing Marble's with their blades) it'll be interesting to see what the next material is that finds its way into the main line. I very much hope they stay in the non-stainless tool steels and don't fall into S30V land with the rest of the lemmings, but only time will tell. There's something about the idea of a stainless Woodsman that's just disturbing...
There's a little bit there. Trailmakers have a much wider blade than even the larger Ideals and the convexion is much more subtle. I've yet to find one, however, that wasn't at least slightly convex. Of course, it can end up being so slight that it might as WELL be a flat grind, but qualifies as convex none the less.![]()
