Among Tojiro range only (
http://www.japanesechefsknife.com/AogamiSteelSeries.html) range are Japanese style knife. Most of others are western style, so no worries. And bladeThickness:1mm probably error of typing, it looks 2-3mm.
BTW, Each kind of genuine Japanese knives, most has a single bevel to shapen easily, made from two layers laminated carbon steel(neither damascus and stainless), and designed specific purpouse. For example Yanagiba thin and long at least 24cm kinfe for a professhional, has a extremely sharp edge but fragile, for slicing SASHIMI with single stroke, not for chopping.
Sharping Yanagiba, is a bit complicated and delicate way therefore
can be sharpend only by flat stones with appropriate hands.
On the other hand, Deba, has a heavy and thick (5mm to 10mm) blade which has a double bevel in 1/3 to 1/2 from handle, the rest of the blade has a single bevel (however factory edge has a single bevel, you need to modify it), the part of double bevel for chopping, to cut fish bone or other tough materials, and tip section for finer work, however Deba is designed rough preparation work, particularly to do heads and tails off guts out from whole fish. Deba can be retouched with ceramic rods, butcher's steel because it robust made.
There also several kind of japanese style knives are available, a thin square blade for fine work for vegitables, a knife for puffer fish to make extreamly thin Sashimi, for eels a small 2 inches blade, so on.
In home kitchen, usually knives are used only stainless steel Santoku, which means three ways, or western style knivese. There aren't a big difference from western kitchen.
I recommend for a first choice Santoku, which you may have seen Blade magazine June 2006, for general purpouse has both advantage of Japanese and western style. Or you can go with western style knives with a fine Japanese blade. These knives have ordinally double bevel, can be sharpen ordinally manner.
PS. Gyuto is a western style that no need special attention.
