blade tip repair
If its less than 1/8 inch then normal sharpening will take care of it. If its more then grinding of the spine may be required.
I was real proud of the work I did on an Al Mar folder. It had about 3/16ths of a broken tip. I slowly grinded the spine down keeping the original blade pattern in tact. Once I was almost to a fresh point, I started rebeveling the edge and it met up with the point very nice. I then polished the spine so it matched the original spine finish. It was alot of fun. I used a drill bit stone about 2" diameter on a Harbor Freight drill press for the grinding.
