I recently bought a Blast Match designed to be used one handed. The construction was cheap and the results were IMHO, poor. The ferrocium rod is spring loaded and you hold the tab that controls the striker tension. You then push the rod down on your tinder bundle. The rod continually stayed jammed in the compressed position.:thumbdn: You'd be better served by obtaining the Swedish Army type of firesticks. I do not feel that you can depend on this kit when the chips are down. If you do own one, I hope that you have better luck than I did.
