Blem #12 received
Bill:
Just got #12. THe knife is great - just what I "needed." The sheath is very loose - in fact the blade will fall right out if your not careful and tilt it the wrong way. Any advise as to what technique and material to put into the sheath to give it a tighter fit? Any advice appreciated. Thanks!
Loki,
Try gluing a couple of pieces of thin leather inside the sheath, that should tighten it up a bit without having to take the sheath apart. Use a flat stick to press the leather down inside the sheath,use leather glue(like Barges)or a rubber cement.
Hope this helps.
Terry
I'll give that a try! Hopefully I won't have to ask about getting a gluded in Khukri our of a sheath.
