troutfisher13111
- Mar 30, 2006
Yikes…If you like your lungs, I don’t suggest you mix soap and bleach.a short soak in a strong solution of bleach with a squirt of dawn mixed in should take that right out
that's essentially how they make Tilex. some detergents are compatible while others are not. simple green is not and while most dishwashing liquid is. in my line of work I have to use bleach. when I make my own "Tilex" I can mix it at whatever strength I need and it works many times better then straight bleach without the dawn. I believe it helps with the surface tension and penetration into the pores. the reaction seems more vigorous and mold and mildew will literally disappear right in front of your eyes as you spray it. I've used it for blood stains, hair dye, ink, etc on linens, mold and mildew on tub caulking, ceilings, and ice machines to clean and sanitize. even our housekeepers state that it works better then the commercially bought stuffYikes…If you like your lungs, I don’t suggest you mix soap and bleach.
Back on topic, I’d clean it up, apply some mineral oil or wax, and leave it be.
I mixed bleach and dish soap in a mop bucket when I was a 16 year old kid and ended up shutting down the pizza joint I worked at for a the rest of the night. All we had was the front and back door, and the drive thru window, couldn’t air the place out fast enough.that's essentially how they make Tilex. some detergents are compatible while others are not. simple green is not and while most dishwashing liquid is. in my line of work I have to use bleach. when I make my own "Tilex" I can mix it at whatever strength I need and it works many times better then straight bleach without the dawn. I believe it helps with the surface tension and penetration into the pores. the reaction seems more vigorous and mold and mildew will literally disappear right in front of your eyes as you spray it. I've used it for blood stains, hair dye, ink, etc on linens, mold and mildew on tub caulking, ceilings, and ice machines to clean and sanitize. even our housekeepers state that it works better then the commercially bought stuff
yeah, not the same thing. I'm going to guess that it was the commercially provided dish soap from some place like ecolab, Zep or similar. no telling what's in it. that's why I've specifically stated to use Dawn as its already been tested to be compatible. I use it almost daily and while stronger then your typical bleach it won't shut the place downI mixed bleach and dish soap in a mop bucket when I was a 16 year old kid and ended up shutting down the pizza joint I worked at for a the rest of the night. All we had was the front and back door, and the drive thru window, couldn’t air the place out fast enough.
What he said...In my opinion it adds character to the knife. I'd leave it.
