I just got a type K TC, and a PID to read it with. I also got the ceramic sheath to protect the TC. My question is how to make the best use of it in a single burner blown forge? Should I go in through the side of the forge with the ceramic sheath? Maybe lay the ceramic inside the lining from the front? Or should I just take readings from the front opening as needed? If I just leave it loose would it be practical to check temps from the front, ideally inside my HT baffle, without burning the wires? I will start lining the forge tomorrow so I can build the TC sheath in as needed...Thanks!
