I thought this was a nice piece of work. It is nice to see a really different Blade from time to time. Click here, hope you enjoy :http://www.talkblade.info/viewtopic.php?t=8853
The problem with doing this to a knife is that that great blue color comes on about 550F or so. That going to make for a softer knife.
I understand what your saying but the last stage of hardening/tempering a blade is to take the metal to temperature (usually about 600F) for 20 minutes, depending on the metal. On certain types of Damascus (because each uses different blends of metals) you can achieve a very bright blue (like the one pictured) if you take the metal to a very closely monitored 550 - 575F. If done just the right way, on the final tempering process, you will have a very hard & very blue blade, of course all things concidered.
JCasewell did say "softer" blade and he is very right because everything needs to be just right or you can wind up with a soft knife.
Respectfully said and by no means trying to say JCasewell was wrong.
Only showing a possible method that may have been used depending on the metals in the Damascus, since it was not listed in the post.
Always best wishes to all
The maker has added to his post. 572-575F is what he says he tempers to. My admiral 0-1 says 600F will temper to 52-56 which is pretty broad but 575F might make it 56 or higher. I'm curious how the damascus would differ.
correct me if i am wrong but quickly taking a metal to a high temp (i.e. not letting it soak in that temp) will still color it wont it? i know you can hit metals with a torch quickly and color them (i know if they are thin it can soften them some but not a whole lot).
basicaly what im trying to get at is how long does a blade really need to be soaked at to temper it down VS the lenght it has to be soaked to color?
-matt
"My ASM atlas of iso transformation TTT diagram shows 600F would produce 49Rc in O-1, 56 Rc @ 500F.
Anyway you slice it, it's sub-optimum hardness for a knife IMO. I can't see sacrificing steel performance for a pretty blue finish."
Thanks J. I agree , thats too soft for performance.
I read that whole blue Damascus project, if you read it all (not a bad read, a little long) but the maker says he takes the blade to 450F in the last sage of tempering, he caught his type-O when he re-read the tread.
Anyway, This would make the blade about a 57-58 rc if I 'am not mistaken, does anyone know for sure because I was going to try a blue blade to see the out come and would like any input.
Thanks.
