I've been using a cold black solution for the last few years that have added years to my life by not having to suck bluing fumes into my lungs.
A company in Britian called Jenolite manufactures a product identified as KoldBlak that will convince the most hard-core 'hot' bluers. I also understand that this product is now available under a new name which I will try to get for you ASAP.
It takes a little time (half hour max) but the finish is impressive. I use a plastic window box as a tank and an old wire strainer as my basket. I use another window box for my oils and some rough wool cloths as my carder. This product will allow you to 'layer' your finish depending on the depth you want the finish to be. I have blackened Browning HiPowers, Wichester 94's (Pre and Post '64), Remington 700 actions and barrels and complete 870's all with great success. I find that the metal preparation is the key to any successful bluing and the same is true for this process as well. I've even refinished a couple of carbon steel blades.
Please note that this blackens carbon steels, NOT stainless.
Hope that these posts have given you some options worthy of consideration.
All the Best
Dileas Gu Brath
