munk said:Satori,
It doesn't have a hand guard. How important is that as a military knife, and for your use personally?
DR, the blueing will work as long as the blade is carbon steel and not stainless.donutsrule said:I was going to try some Birchwood Casey on my practice sword (a sansibar). The blade has a pretty rough finish, and I couldn't get a hot vinegar & lemon juice etch to take. Do you think the blueing would work?
Yvsa said:DR, the blueing will work as long as the blade is carbon steel and not stainless.
After the intermittenet cleanups it will be easy to touch up the blueing. Me Likey Blueing!![]()
The two most important things are cleanliness and heat. I clean my blades with laquer thinner or any high power cleaner with no oil residue, can't think of the damned stuff at the moment, but available at the Home Stores.
Then I run the parts to be blued under straight hot water until any spots evaporate instantly when removed from the source.
Then just follow the directions.
Great!donutsrule said:Thanks, I just picked up a bottle of Perma-Blue so we'll see what happens. If it looks okay on the practice blade, I'll try my 12" Village AK next.![]()
