I too have used Perma-Blu with pretty good success. I can't tell you how long it will last with a chopping blade because I polished it off because I got bored with it before i actually used it
What I was told to do by some members of the Cantina back in 2002:
Wash the blade REALLY REALLY well in HOT water with dish soap. The water should be hot enough that it heats the blade to the point where the water droplets start to evaporate off (most taps will go this hot. The one in my crappy apartment at the time did).
Use paper towels to get all traces of water off the blade.
Make sure that you don't get any grease from your fingers on the blade while you are prepping it.
You might want to use cotton balls and rubbing alcohol to completely clean the blade. As you wipe it down you'll see how unclean your "clean" blade is. Just keep washing the blade down until all traces of dirt stop showing up on the cotton balls.
While it is still warm, apply the blu per the directions on the bottle. I liked using the cotton balls for this.
Then it is just a matter of applying and buffing until it is as dark as you like.
The khuk that I did this to was my first khuk. A Kumar made 15" Villager Model. It had a satin finish, so I have no idea how well the bluing will stick to a polished model. I just etch my khuks with acid now.
Good luck:thumbup:
